I am not an Cpp specialist. I tried out the sample code, set a breakpoint but this didn#t work out. Error is, no symbols loaded. How to fix?
Thanks for helping.
With best regards
Gerhard
Thanks for helping.
With best regards
Gerhard
If I see correctly on the image you are having a break point inside Int_Demo but you are running Gpio_Demo.
If you want to put a break point inside Int_Demo you need to set Int_Demo as startup project.
