it is a nice method to use a string to configurate an GPio pin, but I miss a list of allowed keywords and Parameter values.
I have seen dir, lvl, pull … any more out there?
With best regards
Gerhard
With best regards
Gerhard
Dear @Gerhard
Please open the help file which is part of the library download package. Make sure you read the important note first, which is on the page where you downloaded the libraries.
The keywords are described in a separate section explaining the configuration parameters for each library.
Regards, Andy
