I recently received a Colbri Evaluation Board v3.2 with a VF50 module. I connected everything and it worked great. I was able to compile and run some test programs using VS 2008. I had no problem using the FTDI USB-to-UART converter with a Terminal program.
I spent a day to see if I could flash Embedded Linux to the VF50. I didn’t have any luck getting it to work, but the VF50 and Eval Board continued to function with WinCE through last night.
When I powered them up this morning I noticed that I was not seeing any output to the monitor or to my Terminal software-could not enter bootloader. The FTDI USB was still registering a COM Port but I could never get anything to work like it had before. All LED’s and buttons (power, reset) seem to work just fine.
I tried using the recovery button (SW9) procedure but that didn’t help at all. I’m afraid WinCE in the Flash is corrupt.
I looked into reflashing the OS but without seeing anything in my Terminal window I’m concerned that I’m stuck.
What can I do? Thanks.
