I’m following the instructions at Downloads & Installers | Toradex Developer Center, “Load Toradex Easy Installer” tab, to load Easy Installer 1.7 on an Apalis iMX6 / Ixora V1.1a board. I’ve read the community pages looking for a failure similar to mine, and although I’ve found a few, the solutions on those pages haven’t worked for me.
Here’s the procedure I followed:
Carrier board powered off, jumper JP2 removed. Connect microUSB cable from host machine to X9 on underside of carrier board. RESULT: LED3 illuminates.
Serial adapter connected to X22, terminal open on host.
Hold spacebar down, power ON the carrier board. RESULT:
U-Boot 2016.11-2.8.3+gaca804c9dd (Sep 12 2018 - 21:28:29 +0000)
CPU: Freescale i.MX6Q rev1.5 at 792 MHz
Reset cause: POR
I2C: ready
DRAM: 2 GiB
PMIC: device id: 0x10, revision id: 0x21, programmed
auto-detected panel HDMI
Display: HDMI (1024x768)
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX6 Quad 2GB IT V1.1C, Serial# 05185031
Net: using PHY at 7
FEC [PRIME]
Apalis iMX6 #
On host, ‘lsusb’ does not list any Freescale devices.
In terminal window, type 'bmode usb. RESULT:
Apalis iMX6 # bmode usb
resetting ...
On host, ‘lsusb’ shows no change.
On host, in separate window, type ‘./recovery-linux.sh’ RESULT:
Downloading Toradex Easy Installer...
no matching USB device found
Downloading Toradex Easy Installer failed...
[114322.573078] usb 3-7: new high-speed USB device number 74 using xhci_hcd
[114322.701104] usb 3-7: device descriptor read/64, error -71
[114322.937103] usb 3-7: device descriptor read/64, error -71
[114323.173066] usb 3-7: new high-speed USB device number 75 using xhci_hcd
[114323.301097] usb 3-7: device descriptor read/64, error -71
[114323.541069] usb 3-7: device descriptor read/64, error -71
[114323.649168] usb usb3-port7: attempt power cycle
[114324.301106] usb 3-7: new high-speed USB device number 76 using xhci_hcd
[114324.301238] usb 3-7: Device not responding to setup address.
[114324.509213] usb 3-7: Device not responding to setup address.
[114324.717113] usb 3-7: device not accepting address 76, error -71
[114324.845109] usb 3-7: new high-speed USB device number 77 using xhci_hcd
[114324.845197] usb 3-7: Device not responding to setup address.
[114325.053145] usb 3-7: Device not responding to setup address.
[114325.261048] usb 3-7: device not accepting address 77, error -71
[114325.261075] usb usb3-port7: unable to enumerate USB device
Win 7 not always works as expected in that situation. I’d recommend to try to found a Win10 machine. And also try another USB cable. Many of them not very reliable.
I’ll do that. It will be another 24 hr before I have a result to report. All of our Windows computers here are Win 7 native or Win 7 virtual machines.
(In the meantime, I can use tftp to install Easy Installer, so our development work isn’t halted. But I would like to use the USB OTG method as an alternative method.)
