Hello:
I have been successfully performing my own oe builds for my application. I want to build an image with the boot2qt stack built in. Is there a recipe for this? There is an image for qt-x11 but I don’t think this is what I want.
Hello:
Dear @emh203
Boot2Qt is maintained by the Qt Company. You have two possibilities. You can follow this guide:
http://doc.qt.io/QtForDeviceCreation/qtee-custom-embedded-linux-image.html
Or you can checkout the following repo:
git clone http://code.qt.io/cgit/yocto/meta-boot2qt.git/
cd meta-boot2qt
./b2qt-init-build-env init --device colibri-imx7
MACHINE=colibri-imx7 . ./setup-environment.sh
# Manually update MACHINE in conf/local.conf to colibri-imx7
I hope this helps!
Stefan
