How to use dedicated GPIOs to sleep and wakeup this board from userspace? Can somebody please throw some light here ?
hi @amit251291
Could you provide the version of the hardware and software of your module? Which carrier board are you using?
To get more Information about sleep and wakeup of the module, please consult this page.
What is this?
The hardware version is written on the module?
The Software version can be seen by the command: cat /etc/issue
Is your Issue solved?
Version is
Apalis IMX6Q 2GB IT
V1.1C
05146372
Thanks for the answer.
