I work with thw Viola Board V1.2B and use an i.MX6ULL with the Image:Colibri iMX6ULL (2.8b4 | 2018-10-05)
The UART connection the the terminal on the Linux Host works fine.
Problem:
I cannot stop the U-Boot with any key on boot phase ?
What can be the reason ? (Ii seems do be no hardware problem, because Terminal works fine with UART)
I also have an issue with this. Something similar, but mine is stuck at the kernel (…because it’s bad)
The problem is I can’t get to stop the u-Boot before to change the environment (bootdelay) either to reflash the image … because of the process… it’s not finishing…
I did a try with the minicom - “hardware flow control - No”
But nothing happened…
Should I press repeatedly a button or holding it or keystrokes maybe or ??
Any comment may help! I would very appreciate in advance!
