I am trying to add Wifi Support to our Apalis T30 Mainline-Linux image, based on poky-tiny. The Wifi module is uBlox ELLA-131 (Marvel SD8787). I think I’ve successfully built the kernel. I added Marvel EX driver for SD8787. Additionally, I downloaded the firmware, and compiled it directly into the kernel. Does my boot log look successful?
[ 5.736504] tegra-ehci 7d008000.usb: new USB bus registered, assigned bus number 2
[ 5.744688] tegra-ehci 7d008000.usb: irq 96, io mem 0x7d008000
[ 5.775362] tegra-ehci 7d008000.usb: USB 2.0 started, EHCI 1.00
[ 5.782334] hub 2-0:1.0: USB hub found
[ 5.786156] hub 2-0:1.0: 1 port detected
[ 5.790954] iommu: Adding device ci_hdrc.0 to group 73
[ 5.800323] sdhci-tegra 78000000.sdhci: Got CD GPIO
[ 5.813507] mmc2: Invalid maximum block size, assuming 512 bytes
[ 5.875811] mmc2: SDHCI controller on 78000000.sdhci [78000000.sdhci] using ADMA
[ 5.883785] sdhci-tegra 78000400.sdhci: Got CD GPIO
[ 5.895949] mmc1: Invalid maximum block size, assuming 512 bytes
[ 5.955804] mmc1: SDHCI controller on 78000400.sdhci [78000400.sdhci] using ADMA
[ 5.970976] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.977654] [drm] No driver support for vblank timestamp query.
[ 6.008826] mmc1: new high speed SDIO card at address 0001
[ 6.104171] Console: switching to colour frame buffer device 128x48
[ 6.127151] drm drm: fb0: frame buffer device
[ 6.131712] [drm] Initialized tegra 0.0.0 20120330 for drm on minor 0
[ 6.139571] input: gpio-keys as /devices/soc0/gpio-keys/input/input1
[ 6.148185] hctosys: unable to open rtc device (rtc0)
[ 6.206459] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.712285] mwifiex_sdio mmc1:0001:1: info: FW download over, size 463240 bytes
[ 6.835430] mwifiex_sdio mmc1:0001:1: WLAN FW is active
[ 7.075999] mwifiex_sdio mmc1:0001:1: CMD_RESP: cmd 0x242 error, result=0x2
[ 7.083075] mwifiex_sdio mmc1:0001:1: mwifiex_process_cmdresp: cmd 0x242 failed during initialization
[ 8.065844] igb 0000:01:00.0 eth0: igb: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
[ 8.104403] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.125685] Sending DHCP and RARP requests .
[ 8.125780] NOHZ: local_softirq_pending 08
[ 8.137311] NOHZ: local_softirq_pending 28a
[ 8.144488] NOHZ: local_softirq_pending 2ca
[ 8.151660] NOHZ: local_softirq_pending 2ca
[ 8.158771] NOHZ: local_softirq_pending 2ca
[ 8.165844] NOHZ: local_softirq_pending 2ca
[ 8.172828] NOHZ: local_softirq_pending 2ca
[ 8.179748] NOHZ: local_softirq_pending 2ca
[ 8.186650] NOHZ: local_softirq_pending 2ca
[ 8.201662] mwifiex_sdio mmc1:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (14.66.35.p52)
[ 8.212594] mwifiex_sdio mmc1:0001:1: driver_version = mwifiex 1.0 (14.66.35.p52)
I then added CORE_IMAGE_EXTRA_INSTALL += “packagegroup-base-wifi” to my local.conf. Is there a way to add this to meta_my_poky layer instead of local.conf?
If I do ifconfig, I don’t get any WLAN device in the list. wpa_cli gives a message "could not connect to wpa_supplicant: (nil) - retrying. It’s possible I am missing some configuration. I feel like I got the hard part right, loading the kernel driver and firmware, but am missing something obvious.
25. [ 7.083075] mwifiex_sdio mmc1:0001:1: mwifiex_process_cmdresp: cmd 0x242 failed during initialization
I guess above is the issue which may be worked around according to the information I found googling here.
Yes, you would just bbappend resp. image recipe or even create your own as e.g. outlined here.
Really looks like a driver issue. On your particular device, certain commands seem unsupported.
The command that isn’t supported is set country code. It is normal for that to fail. I applied the patch you mentioned, and it just skipped that config step and did the same thing.
Is this the correct firmware version for u-Blox ELLA-W131 (WiBear) - mwifiex 1.0 (14.66.35.p52)?
How do I enable more debugging to get more info at the driver level? Are there any known issues with MMC1 on Apalis T30 with mainline, other than the toradex 4.14.y mainline patches?
I managed to get uBlox ELLA-W131 (Marvell SD8787) working with toradex-mainline 4.14.y. For the kernel, I changed networking->wireless->mcf80211 to y. Driver->Network Device->Wireless LAN->Marvel Wifi-EX Drive and SD8787 to yes. I added Driver->Generic Driver Options->Include in-kernel firmware blob as mrvl/sd8787_uapsta.bin. Add to build/local.conf: CORE_IMAGE_EXTRA_INSTALL += “packagegroup-base-wifi”
wpa_supplicant -imlan0 -c/etc/wpa_supplicant.conf -B (-B run in background once working)
udhcp -i mlan0
At this point, I had an IP address for mlan0 and registered to the AP. So i unplugged the wired ethernet and issue ifconfig eth0 down and ping over the wireless, and it works. Hopefully some of this is useful to someone else, but I am happy to have it working.
