When creating a new MFC project only one type of project gets created which seems to be a single-document type.
How can I create a simple dialog type project?
Dear @pkijoe
I’m afraid Microsoft removed the dialog option from the VS2015 project wizard.
I created a dialog project in VS2008 and loaded it into VS2015. Here is the result:
The conversion from VS2008 to VS2015 fails, and needs some manual correction steps. Basically:
- Before converting the project, open the *.vcproj file in a text editor, and replace all configuration names
Toradex_CE800 (ARMv7)
byToradex_CE800
. - In the VS2015 configuration editor, remove all configurations except
Toradex_CE800
. - In the linker options, enable randomized base address
- In the linker options, disable the generation of a manifest
- In stdafx.h, remove the line
#include <altcecrt.h>
Regards, Andy
Great ! Thank you.
