I have asked a question in here before (https://www.toradex.cn/community/questions/30588/apalis-tk1-touchscreen-calibration-issue-1.html)
So, what I found so far is that
I have confirmed that the touchscreen device works well with IMX6q Apalis board. However, with Apalis TK1 board, it shows faster moving than I input, and giving wrong locations
it has a difference touchscreen pixel numbers when I (TK1 case : min 0, max 32768, IMX6q case : min 0, max 4068)
with xinput_calibrator, I found that imx6q matches “stmpe-ts” driver while tk1 matches “Silicon Works Multi-touch Device”
So, so far, my approach is that I am trying to make TK1 use “stmpe-ts” driver. So I was wondering if you could give me any advice on this. What I did was
Menuconfig → STMPE driver activated
In tegra124-apalis-dtsi file, I added
/* STMPE811 touch screen controller */ stmpe811@41 { compatible = "st,stmpe811"; #address-cells = <1>; #size-cells = <0>; reg = <0x41>; interrupts = <TEGRA_GPIO(V, 0) IRQ_TYPE_LEVEL_LOW>; interrupt-parent = <&gpio>; interrupt-controller; id = <0>; blocks = <0x5>; irq-trigger = <0x1>; stmpe_touchscreen { compatible = "st,stmpe-ts"; reg = <0>; /* 3.25 MHz ADC clock speed */ st,adc-freq = <1>; /* 8 sample average control */ st,ave-ctrl = <3>; /* 7 length fractional part in z */ st,fraction-z = <7>; /* * 50 mA typical 80 mA max touchscreen drivers * current limit value */ st,i-drive = <1>; /* 12-bit ADC */ st,mod-12b = <1>; /* internal ADC reference */ st,ref-sel = <0>; /* ADC converstion time: 80 clocks */ st,sample-time = <4>; /* 1 ms panel driver settling time */ st,settling = <3>; /* 5 ms touch detect interrupt delay */ st,touch-det-delay = <5>; };
But, still no luck right now.
Thank you in advanced!
