The issue is with the libcrypto++9v5:i386 I have the error:
E: Unable to locate package libcrypto++9v5:i386
E: Couldn't find any package by regex 'libcrypto++9v5'
Note: I want to create an image of a linux distro (centOS) with yocto/OpenEmbedded (core) and then burn it on the embedded system so if you have any tutorial this would be very interesting.
developement workstation environment ( ubuntu 18.04 64 bit).
I don’t get why this package in particular is causing trouble.
Concernining oe/yocto, I am new to OpenEmbedded/yocto maybe I didn’t understand correctly. In the yocto docs it said: it’s not an embedded linux distro. So on which distro is yocto based to create image? From what I understood, given a linux distro ( exemple centOS) we can customize it with yocto.
What exact build are you attempting? Most likely Ubuntu 18.04 is not suitable to build whatever older OpenEmbedded/Yocto Project version. I recommend using a stable Debian container instead.
I don’t think your current understanding of OpenEmbedded/Yocto Project is correct. It may only be used to build custom OpenEmbedded/Yocto Project images, nothing more and nothing less, sorry.
