Analogue Camera Adapter: Switch Analog Input
This is related to the post
I’ve one more question, how can I switch the analog input of the module? I’m trying to find this looking at the code example here without success. Thanks in advanced.
Dear @skabo
I quickly checked the demo code. Please look at the file sensor_yuv_ADV7280.c. In line 335 ff. there are the statements:
//Enable autodetection
data[0]=ADV7280_INPUT_CONTROL_AD_PAL_BG_NTSC_J_SECAM | ADV7280_INPUT_CONTROL_COMPOSITE_IN1;
if(I2CBurstWrite(I2C_ADDRESS, data, ADV7280_INPUT_CONTROL, 1)  == FALSE) goto ERROR_EXIT;
data[0]=ADV7280_AUTODETECT_DEFAULT;
if(I2CBurstWrite(I2C_ADDRESS, data, ADV7280_AUTODETECT_ENABLE, 1)  == FALSE) goto ERROR_EXIT;
I checked out the ADV7280 User Guide:
The input selection is described in Table 104. User Sub Map Register Descriptions.
I expect it should be sufficient to replace the constant ADV7280_INPUT_CONTROL_COMPOSITE_IN1 with the appropriate value, and disable autodetection.
Regards, Andy
ok, I’ll test it and back to you.
