How to use Wireless Vibration sensor with Toradex Colibri boards
Since Toradex hardware seems kind of industrial IOT boards to create the flexible environment between Internet Servers, I need some suggestion which is the best to interface wireless vibration sensor for creating a industrial grade maxchine health monitoring system ?
I’m not familiar with a National Control Devises products, but apparently they are using XBee solutions. So you can install module like this one - Long Range 900 MHz OEM RF Module | Digi XBee-PRO 900HP | Digi International and communicate with colibri module using provided UART or SPI interface. Or you can use NCD provided USB modem (https://store.ncd.io/product/900hp-s3b-long-range-wireless-mesh-modem-with-usb-interface/). It’s uses Serial 2 USB protocol and should work with Colibri modules out of box.
