I’m having troubles trying to get my application with a quiet boot. All I want is to have a blank screen during the startup until my Application shows up.
I know that you can fix it by messing with the image’s source code, but I have no access to it, so there is a couple things i have already try:
- Disabling framebuffer(s) (Vidargs).
- Disabling console(s) (setup)
- Changing the printk function so it doesn’t print message unless they are emergency ones (But I don’know if Idid it right)
- Changing the stdoutoutput (Bootcmd)
- Removing the echo function so it does nothing
