I have a technical question on the new Colibri imx8 pinout of X1 connector, actually it’s more confusion
With imx6, imx6ULL, imx7,…etc the UART convention on TX and RX pins at the X1 connector level were consistent, they were flipped, but at least consistent. Now on the imx8 looks like the flip between Tx Rx has been removed and hence there seems to be an incompatibility, at least on “paper” See table below to better understand what I am talking about:
Personally I have not been trusting the X1 name, and go directly to the processor UART peripheral to check for Tx or Rx pin function.
Based upon this there is discrepancy.
So the i.MX 6 has an UART which can do both DCE and DTE mode. The i.MX 6 pin TX is input, RX is output regardless of what mode is set, i.e. they got their name from the DCE mode.
The i.MX 8X has a different UART IP which works in DTE mode only. The i.MX 8 pin TX is output, RX is input.
The X1 SODIMM names also use DTE mode, so the X1 TX pin is output, RX is input.
With regard to the information above for the i.MX6:
Are the RTS and CTS also named with respect to DCE mode? For example, RTS is an output in DTE mode, but input in DCE mode. According to what you’re saying above, I would expect that the pin labels in the datasheet for RTS and CTS is with DCE mode set. Therefore, if I were using DTE mode, pin 34 is CTS and pin 32 is RTS. Is that correct, or does the swap only apply to RX and TX???
The datasheet states that all pins are presented are in DTE mode. If that’s the case, then the information in the table should already be showing RX and TX as swapped. Isn’t it as shown in the image below? pin 36 is an input and receiving data and pin 38 is an output and is transmitting data?
The colums ‘Colibri Signal Name’, ‘I/O’, and ‘Description’ all describe the pin’s function. I.e. the UART signals in DTE mode.
So pin 34 and 38 both are outputs, the module is providing these signals to the carrier board,
pin 32 and 36 are inputs, the carrier board provides these signals to the module.
Yes.
Please also consult the schematic of e.g. the Colibri Evaluation Board. The RS232 transceiver gives a clear indication on the data direction.
