hi @jaski.tx
Thank you for the welcome.
Could you check with an oscilloscope, if you are receiving any signals on the Rx Line. Is >UART_B working on Linux?
I know that the signal arrives on the Rx Line since I have an application already working on Linux with A7 but I need to move it to the Cortex-M4.
Which Uart_interrupt example are you using exactly?
The one you provide with freeRTOS called uart_interrupt.
Can you share all your changes you have done to the code?
#include <stdint.h>
#include <stdbool.h>
#include "uart_imx.h"
#include "board.h"
typedef struct _uart_state {
const uint8_t* txBuff; /*!< The buffer of data being sent.*/
uint8_t* rxBuff; /*!< The buffer of received data. */
volatile uint32_t txSize; /*!< The remaining number of bytes to be transmitted. */
volatile uint32_t rxSize; /*!< The remaining number of bytes to be received. */
volatile bool isTxBusy; /*!< True if there is an active transmit. */
volatile bool isRxBusy; /*!< True if there is an active receive. */
} uart_state_t;
const uint8_t buffStart[] = "AT\r";
const uint8_t bufferData[] = "AT+UBTLE=1\r";
/* Uart runtime state structure */
static uart_state_t uartState;
static void UART_XFER_Config(uart_init_config_t* initConfig);
static bool UART_XFER_Write(uint8_t* txBuffer, uint32_t length);
static uint32_t UART_XFER_GetWriteStatus(void);
static bool UART_XFER_Read(uint8_t* rxBuffer, uint32_t length);
static uint32_t UART_XFER_GetReadStatus(void);
int main(void)
// Setup UART init structure.
uart_init_config_t initConfig = {
.baudRate = 115200u,
.wordLength = uartWordLength8Bits,
.stopBitNum = uartStopBitNumOne,
.parity = uartParityDisable,
.direction = uartDirectionTxRx
uint8_t rxChar, txChar;
// Initialize board specified hardware.
hardware_init();
// Get current module clock frequency.
initConfig.clockRate = get_uart_clock_freq(BOARD_DEBUG_UART_BASEADDR);
// Initialize the uart module with initialize structure.
UART_XFER_Config(&initConfig);
// Inform to start non blocking example.
UART_XFER_Write((uint8_t*)buffStart, 3);
// Wait until transmission is finished.
while (UART_XFER_GetWriteStatus());
// Call received API
UART_XFER_Read(&rxChar, 1u);
// Wait until we receive a character
while (UART_XFER_GetReadStatus());
UART_XFER_Write(&rxChar, 1u);
// Inform user of what to do
UART_XFER_Write((uint8_t*)bufferData, 11);
/* Assert */
/* Initialize UART state structure content. */
uartState.txBuff = 0;
uartState.rxBuff = 0;
uartState.txSize = 0;
uartState.rxSize = 0;
uartState.isTxBusy = false;
uartState.isRxBusy = false;
/* Initialize UART baud rate, bit count, parity, stop bit and direction. */
UART_Init(BOARD_DEBUG_UART_BASEADDR, initConfig);
UART_SetTxFifoWatermark(BOARD_DEBUG_UART_BASEADDR, 16);
UART_SetRxFifoWatermark(BOARD_DEBUG_UART_BASEADDR, 1);
/* Set UART Interrupt priority */
NVIC_SetPriority(BOARD_DEBUG_UART_IRQ_NUM, 3);
/* Call core API to enable the IRQ. */
NVIC_EnableIRQ(BOARD_DEBUG_UART_IRQ_NUM);
/* Finally, enable the UART module */
UART_Enable(BOARD_DEBUG_UART_BASEADDR);
if ((uartState.isTxBusy) || (0 == length))
return false;
uartState.txBuff = txBuffer;
uartState.txSize = length;
uartState.isTxBusy = true;
UART_SetIntCmd(BOARD_DEBUG_UART_BASEADDR, uartIntTxReady, true);
return true;
return uartState.txSize;
if ((uartState.isRxBusy) || (0 == length))
return false;
uartState.rxBuff = rxBuffer;
uartState.rxSize = length;
uartState.isRxBusy = true;
UART_SetIntCmd(BOARD_DEBUG_UART_BASEADDR, uartIntRxReady, true);
return true;
return uartState.rxSize;
void BOARD_DEBUG_UART_HANDLER(void)
/* Exit the ISR if no transfer is happening for this instance. */
if ((!uartState.isTxBusy) && (!uartState.isRxBusy))
return;
if (UART_GetStatusFlag(BOARD_DEBUG_UART_BASEADDR, uartStatusRxReady))
/* Check to see if there are any more bytes to receive. */
if (uartState.rxSize)
while (UART_GetStatusFlag(BOARD_DEBUG_UART_BASEADDR, uartStatusRxReady))
*(uartState.rxBuff) = (uint8_t)UART_Getchar(BOARD_DEBUG_UART_BASEADDR);
uartState.rxBuff++;
uartState.rxSize--;
if (uartState.rxSize == 0U)
UART_SetIntCmd(BOARD_DEBUG_UART_BASEADDR, uartIntRxReady, false);
break;
if (UART_GetStatusFlag(BOARD_DEBUG_UART_BASEADDR, uartStatusTxReady))
/* Check to see if there are any more bytes to send. */
if (uartState.txSize)
while (UART_GetStatusFlag(BOARD_DEBUG_UART_BASEADDR, uartStatusTxReady))
/* Transmit data and update tx size/buff */
UART_Putchar(BOARD_DEBUG_UART_BASEADDR, *(uartState.txBuff));
uartState.txBuff++;
uartState.txSize--;
if (uartState.txSize == 0U)
/* Transmit complete */
/* Disable the transmitter ready interrupt */
UART_SetIntCmd(BOARD_DEBUG_UART_BASEADDR, uartIntTxReady, false);
/* Update the information of the module driver state */
break;
* EOF
We are simply trying to send the command and get the “OK” reply. We have made different tests in order to get the reply and put it in a buffer but it’s better to get the basic idea behind it and then build our program around this fix.
Regards
