after setting a password for root VF61 denies remote access.
“PermitRootLogin yes” in sshd_config did not help.
Attempt to login as root causes :
“Using keyboard-interactive authentication”
Entering the password causes connection abort.
What is to do ?
Best regards
I suspect that you face some issue as described in the troubleshooting section here.
Hallo Marcel,
thank you for your advice.
Setting a hashtag at “#PermitEmptyPasswords yes” in “/etc/ssh/sshd_config” solved the problem.
Best regards
Glad it is working for you now and thanks for letting us know.
