Hello all,
There was an issue when booting the Toradex platform. I’m unable to boot the device.
Please check the following error. Please help me to fix this issue:
Toradex Bootloader 1.4 for Tegra Built Sep 3 2015
Press [SPACE] to enter Bootloader Menu
Initiating image launch in 0 seconds.
Colibri T20 512MB V1.2A SerialNo: 2544190
RAM: 512 MB, CarveOut: 64 MB
Locating kernel image in flash...ERROR: ROMHDR structure failed consistency checks!
SpinForever...
The OS image is corrupted for an unknown reason. including flashing of an invalid image, a power cut during an image update, or an insufficient error correction in the low-level flash driver.
If you want to investigate the root cause, I need more information about how the module got into this non-booting state.
After that i just loaded locally created nk.nb0(through visual studio) and boot up stopped in between. I’m unable to access any USB ports, so can’t move forward to recovery mode. Please check the attached image and help me to recover from this error.
