I recently connected the 7" capacitive touch display to an Aster carrier board to see if I could get make it work. I was able to get the resolution changed using U-boot but I could never get the touch feature working.
I followed the instructions using the First Steps with Capacitive Touch. I tried all of the commands for the iMX6 but nothing would make a difference. I even tried flipping each end of the connector to see if it would help.
I also tried two separate displays and two separate cables.
Below are two text files. One is a dmesg log and the other is the output for fw_printenv fdt_fixup
link text
I also took photos (below) of my installation.
link text
Any suggestions would be greatly appreciated. Thanks.
Scott
Hi @sbickle99
Your connections are correct. Since you are using the dedicated Interface Connector, you need to setup fdt_fixup
differently. You applied the settings for the touch adapter which is needed only for the Colibri Evaluation Board.
Best regards, Jaski
Hi Jaski,
Thanks. I should have known better. I actually tried the other setup first but it didn’t work so I tried the ‘dedicated Interface Connector’ option just to see if it would make a difference.
My current fdt_fixup setup is below. Unfortunately it hasn’t made a difference.
setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt set /soc/aips-bus@02100000/i2c@021a8000/atmel_mxt_ts@4a status okay'
Just to be clear, should I notice the touch working on the linux desktop after trying this command? Trying the modprobe atmel_mxt_ts
option also does nothing.
Are there any other commands or tests I can run that help clarify things? Thanks again.
Scott
Hi Jaski,
I decided to try the display using WinCE and the touch works just fine. So, I can confirm that the connections and hardware are working properly.
I’m just not able to get it working with Linux, which is what I need for our application.
Scott
Hi Jaski,
I tried again using Linux and received the following output when executing the modprobe atmel_mxt_ts
command.
[ 337.296977] imx6dl-pinctrl 20e0000.iomuxc: pin MX6DL_PAD_EIM_CS1 already requested by 21b8000.weim; cannot claim for 2-00a
[ 337.308324] imx6dl-pinctrl 20e0000.iomuxc: pin-80 (2-004a) status -22
[ 337.314913] imx6dl-pinctrl 20e0000.iomuxc: could not request pin 80 (MX6DL_PAD_EIM_CS1) from group mxt-ts on device 20e0c
[ 337.326808] atmel_mxt_ts 2-004a: Error applying setting, reverse things back
root@colibri-imx6:~# [ 337.462408] atmel_mxt_ts 2-004a: Direct firmware load for maxtouch.cfg failed with error -2
[ 337.470831] atmel_mxt_ts 2-004a: Falling back to user helper
[ 337.488264] atmel_mxt_ts 2-004a: T100 Touchscreen size X799Y479
[ 337.496087] input: Atmel maXTouch Touchscreen as /devices/soc0/soc/2100000.aips-bus/21a8000.i2c/i2c-2/2-004a/input/input7
[ 337.512584] atmel_mxt_ts 2-004a: Family: 164 Variant: 11 Firmware V1.2.AA Objects: 41
Any ideas on why I’m getting these errors? Thanks.
Scott
hi @sbickle99
Thanks for the log. You need to set the uboot variable fdt_file
device tree file to imx6dl-colibri-aster.dtb
You can do this in two ways, either from Uboot or Linux.
UBoot: # setenv fdt_file 'imx6dl-colibri-aster.dtb'
Linux : fw_setenv fdt_file imx6dl-colibri-aster.dtb
We need to add this in the documentation. Sorry for the Inconvenience.
Best regards, Jaski
Hi Jaski,
Thanks! It’s working now.
Scott
