I have colibri evaluation board with imx7d.
Ehternet was working fine, but it stopped working from yesterday.
I have another imx7d module, in that its working fine.
I tried to update it with toradex easy installer, but there also it did not detect the Ethernet port.
It would be great if someone could help me debug this.
hi @abhilash
Could you provide the version of the Hardware and Software of your module?
Is it possible that you install a regular Bsp image using SD card and then also reset the uboot environment?
Please check then if the Issue is still present?
Best regards, Jaski
Hi @jaski.tx ,
Thanks for your reply.
root@colibri-imx7-emmc:~# uname -a
Linux colibri-imx7-emmc 4.1.44-2.7.4+gb1555bf #1 SMP Wed Oct 4 21:39:05 UTC 2017 armv7l GNU/Linux
Hardware Version: Colibri iMX7D 1GB V1.1A
I installed colibri-imx7-emmc_lxde-image-tezi_2.7-20180104.tar and i did reset.
The issue still present.
But other colibri modules are working with same image.
Could you provide the complete UBootl log in a file? Thanks
I have attached the complete boot log file.
boot log download
Thanks for the log. The PHY seems to work.
Do you see the Ethernet Port Led blinking when the module is started?
What is the output of ifconfig
How is your network setup?
I do not see led blinking.
What is the output of ifconfig?
root@colibri-imx7-emmc:~# ifconfig
eth0 Link encap:Ethernet HWaddr 00:14:2D:2D:BB:B8
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1%1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:324 errors:0 dropped:0 overruns:0 frame:0
TX packets:324 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:23920 (23.3 KiB) TX bytes:23920 (23.3 KiB)
usb0 Link encap:Ethernet HWaddr 00:14:2D:FF:FF:FF
inet addr:192.168.11.1 Bcast:192.168.11.255 Mask:255.255.255.0
We have a dhcpc server running.
Other colibri imx7d modules are working fine with the dev board with the same image.
HI @abhilash
If other modules are working with same Software then it seems to be a hardware issue. Sorry that you have this experience with the Toradex Hardware. You can ask for a RMA and put this community post as reference.
Thanks and Best regards,
