I 've a issue with “node red”.
I installed “node red” on VF61.
It can be started via PuTTY.
Entering : “node-red” starts the application
and it works.
Now I want it get startet with booting.
I created a file “node-red.service” with the content:
[Unit]
Description=node-red Service
After=multi-user.target
[Service]
Type=simple
ExecStart=/usr/local/bin/node-red
[Install]
WantedBy=multi-user.target
I copied it to “/etc/systemd/System”
Then I called :
"systemctl --system daemon-reload"
"systemctl enable node-red.service
and
“reboot”
followed by:
"systemctl status node-red.service"
and that is shown on screen:
[[0;1;31m●[[0m node-red.service - node-red service
Loaded: loaded (/etc/systemd/system/node-red.service; enabled; vendor preset: enabled)
Active: [[0;1;31mfailed[[0m (Result: exit-code) since Thu 2019-02-14 12:48:02 UTC; 48s ago
Process: 245 ExecStart=/usr/local/bin/node-red [[0;1;31m(code=exited, status=1/FAILURE)[[0m
Main PID: 245 (code=exited, status=1/FAILURE)
Feb 14 12:48:02 ems5-cp05e node-red[245]: at Module._compile (module.js:643:30)
Feb 14 12:48:02 ems5-cp05e node-red[245]: at Object.Module._extensions..js (module.js:654:10)
Feb 14 12:48:02 ems5-cp05e node-red[245]: at Module.load (module.js:556:32)
Feb 14 12:48:02 ems5-cp05e node-red[245]: at tryModuleLoad (module.js:499:12)
Feb 14 12:48:02 ems5-cp05e node-red[245]: at Function.Module._load (module.js:491:3)
Feb 14 12:48:02 ems5-cp05e node-red[245]: at Function.Module.runMain (module.js:684:10)
Feb 14 12:48:02 ems5-cp05e node-red[245]: at startup (bootstrap_node.js:187:16)
Feb 14 12:48:02 ems5-cp05e systemd[1]: [[0;1;39mnode-red.service: Main process exited, code=exited, status=1
/FAILURE[[0m
Feb 14 12:48:02 ems5-cp05e systemd[1]: [[0;1;39mnode-red.service: Unit entered failed state.[[0m
Feb 14 12:48:02 ems5-cp05e systemd[1]: [[0;1;39mnode-red.service: Failed with result 'exit-code'.[[0m
Please can anybody tell me, what I am doing wrong?
