I’m trying to generate a bring up Apalis iMX8 image as described in the tutorial below:
But I’m stuck at the error below
WARNING: linux-toradex-4.9.51-r0 do_fetch: Failed to fetch URL git://git.toradex.com/linux-toradex.git;protocol=https;branch=toradex_imx_4.9.51_imx8_beta2-bring_up, attempting MIRRORS if available
ERROR: linux-toradex-4.9.51-r0 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-HpAPgZwzW7"; export SSH_AUTH_SOCK="/run/user/1000/keyring-BHNdBj/ssh"; export PATH="/home/rodrigo/imx-yocto-bsp/sources/poky/scripts:/home/rodrigo/imx-yocto-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/aarch64-poky-linux:/home/rodrigo/imx-yocto-bsp/build/tmp/sysroots/apalis-imx8/usr/bin/crossscripts:/home/rodrigo/imx-yocto-bsp/build/tmp/sysroots/x86_64-linux/usr/sbin:/home/rodrigo/imx-yocto-bsp/build/tmp/sysroots/x86_64-linux/usr/bin:/home/rodrigo/imx-yocto-bsp/build/tmp/sysroots/x86_64-linux/sbin:/home/rodrigo/imx-yocto-bsp/build/tmp/sysroots/x86_64-linux/bin:/home/rodrigo/imx-yocto-bsp/sources/poky/scripts:/home/rodrigo/imx-yocto-bsp/sources/poky/bitbake/bin:/home/rodrigo/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"; export HOME="/home/rodrigo"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror https://git.toradex.com/linux-toradex.git /home/rodrigo/imx-yocto-bsp/downloads//git2/git.toradex.com.linux-toradex.git --progress failed with exit code 128, output:
Cloning into bare repository '/home/rodrigo/imx-yocto-bsp/downloads//git2/git.toradex.com.linux-toradex.git'...
**error: Unable to get pack file https://git.toradex.com/linux-toradex.git/objects/pack/pack-88d6515332876cc2e45fef17f9cf18a79103d4a1.pack**
The requested URL returned error: 404 Not Found
error: Unable to find 43f61e8df71c474cd56b5c971096b9cf8d36cd95 under https://git.toradex.com/linux-toradex.git
Cannot obtain needed object 43f61e8df71c474cd56b5c971096b9cf8d36cd95
while processing commit e9e44dabe46ac3ccb87e7e826fa597d53bad7dce.
error: Fetch failed.
ERROR: linux-toradex-4.9.51-r0 do_fetch: Fetcher failure for URL: 'git://git.toradex.com/linux-toradex.git;protocol=https;branch=toradex_imx_4.9.51_imx8_beta2-bring_up'. Unable to fetch URL from any source.
ERROR: linux-toradex-4.9.51-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/rodrigo/imx-yocto-bsp/build/tmp/work/apalis_imx8-poky-linux/linux-toradex/4.9.51-r0/temp/log.do_fetch.5310
ERROR: Task (/home/rodrigo/imx-yocto-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux/linux-toradex_4.9.51.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 7081 tasks of which 7080 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 3 ERROR messages shown, returning a non-zero exit code.
We noticed that the pack-88d6515332876cc2e45fef17f9cf18a79103d4a1.pack does not exist.
Thanks.
