Apalis i.MX6 on Ixora freeze ups with unusual message in dmesg
Have seen one of three Apalis i.MX6Q IT freeze mysteriously 2 times while running a Qt demo program (planets). The other two don’t ever do this. Kernel ring buffer has an unusual message:
[ 142.435387] mmc1: Switching to 3.3V signalling voltage failed
[ 176.902816] mmc2: Switching to 3.3V signalling voltage failed
[ 176.902821] mmc1: Switching to 3.3V signalling voltage failed
Which recurs fairly frequently on the unit. This seems to have never been reported so I am wondering if I have a problem with either the Ixora or the i.MX6 SOM?
Hi
What exact HW and SW version do you use?
Max
Apalis i.MX6 IT Quad on Ixora carrier board
Kernel is console-tdx-image
The problem just stopped happening as suddenly as it started. I have never seen it on any other Apalis or Colibri.
Thanks for letting us know.
Should you experience any further issues please do indicate the exact hardware (module and carrier board) and software versions of things you are talking about.
