I wonder if there is any DTB configuration running the Arduino shield out of the box.
I am struggling to figure out how to use the GPIOs on connector X17.
The Aster seems a limited carrier board and is not well documented as the other like Iris for example.
For example, the only document available for GPIO and Aster is for MX7 and the details are not complete:
For example I want to test UNO_GPIO1 (X17 pin 3) which is connected to SODIMM pin 45
If I run the GPIO tool and I select GPIO and OUTPUT it doesn’t work.
If I set the GPIO 54 as output (corresponding to GPIO2_02)
