When i create with open-embedded the Qt5 X11 image from the LinuxImageV2.8 branch with
$ bitbake angstrom-qt5-x11-image
the following basehash error console output occurs :
“When reparsing /home/stefan/oe-core/build/…/layers/meta-toradex-demos/recipes-images/images/angstrom-qt5-x11-image.bb.do_image_teziimg, the basehash value changed from 959669a01a727dfeb5ee7b6c6587d71f to e871a7dae5cc31b8c928c944c82d7f46. The metadata is not deterministic and this needs to be fixed.”
After cleanall ( tmp/ an sstate-chache/ ) the error still happen.
The Machine configuration in oe-core/build/conf/local.conf : MACHINE ?= “colibri-imx6ull”
Also 5 other error happens around “angstrom-qt5-x11-image.bb:do_populate_sdk”
How can the problem(s) especially the basehash error be solved ?
Is this Qt5 image maybe no longer maintained by Toradex ?
