Installing CE6
Currently have the board at Easy app installer. I’m looking for a way to install CE6 as the os. I know it isn’t compatible at the moment but is there any way around it? I just need it to run a simple application on CE6
I don’t think the Colibri iMX6ULL will ever support any CE at all.
Windows CE support for iMX6ULL is not planned.
If you want to use one of our low-power/low-cost modules you can have Windows CE 6 on Vybrid (VF50,VF61) and CE 7 and WEC2013 (CE7 is binary compatible with CE6, WEC2013 requires at least a rebuild of your application) on iMX7.
