Imx6 vnc no longer works correctly
Since updating my module to version 1. the vnc fails to load on boot like it used to and i have to put a usb with it on.
Once loaded i can see vnc started but didn’t actually do anything pas displaying version info 4.1.3.
After a while the vnc then stops working. It worked fine on the previous image. Any idea what could now be wrong?
We had reports of issues running applications from flash, those seem to be solved in the upcoming 1.1beta2 release that is currently under test and will be release in a few weeks.
