We have a custom UI that we use. We disable the NetUI as explained here: Network Messages Suppress (Hide) from NETUI | Toradex Developer Center so we can use our own popups to gather information to make the UI look uniform.
When we try to connect to wifi using 802.1x enterprise using TLS (certificates) or PEAP (username & password), the network box obviously does not show up to get the information. It then fails to connect. Taking off the registry entry to suppress, we are able to enter credentials and it works
Is there a way to feed the necessary information to the NetUI? Is there a place in the wi-fi profiles to say what username or password (if needed) to use? Is there perhaps some sort of callback to listen to and programatically set that information?
Thanks for the help
