Apalis iMX8 boot - Did not find a cmdline Flattened Device Tree
I’ve just built iMX8QM image and created bootable SD card, on the:
(patches from Errors with GLIBC2.27 while building current Yocto (QEMU and e2fsprogs) - Solution added, please check - Technical Support - Toradex Community were required)
Everything looks good, U-Boot is executed and .dtb read, but following error occurs just before starting the kernel:
reading fsl-imx8qm-apalis.dtb
78493 bytes read in 21 ms (3.6 MiB/s)
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
What could be the problem and how to tackle it?
Thanks,
Piotr
hi @piotr
What changes have you done to the software?
Could you provide the complete u-boot log and .dtb file?
Thanks and best regards,
Dear @jaski.tx
The only changes to the code that I made are the 2 patches described by alvaro.tx in the thread:
Files:
U-Boot log and DTB file
Thanks for the dtb file. I tested the file and it did not work. You could use this dtb file which is just from the bring up image or you can compile yourself the dtb file.
