Hi team,
I opened another question from here.
I’m looking to stablish a simple SPP connection between the ULL and a bluetooth device that will act as SPP server: Basically in Windows associate the Bluetooth incoming connections to a serial COM port.
I’ve been able to connect this between the Serial Bluetooth Terminal android app and TeraTerm (Windows equivalent to minicom), so we can assume that the SPP server is working correctly.
This time I’m trying to use rfcomm
commands to interact with the server. With bluetoothctl
I could connect to the server and confirm the SPP service availability (UUID: Serial Port):
[SURFACELAPTOP]# info F0:6E:0B:D8:D4:E6
Device F0:6E:0B:D8:D4:E6
Alias: SURFACELAPTOP
Class: 0x0a010c
Icon: computer
Paired: yes
Trusted: yes
Blocked: no
Connected: yes
LegacyPairing: no
UUID: Service Discovery Serve.. (00001000-0000-1000-8000-00805f9b34fb)
UUID: Serial Port (00001101-0000-1000-8000-00805f9b34fb)
UUID: Audio Source (0000110a-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: PANU (00001115-0000-1000-8000-00805f9b34fb)
UUID: Handsfree Audio Gateway (0000111f-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
UUID: Vendor specific (c7f94713-891e-496a-a0e7-983a0946126e)
Modalias: bluetooth:v0006p0001d0A00
Now, I’m trying to connect to the server and create my /dev/rfcomm
device node:
root@colibri-imx6ull:~# rfcomm connect /dev/rfcomm0 F0:6E:0B:D8:D4:E6
Connected /dev/rfcomm0 to F0:6E:0B:D8:D4:E6 on channel 1
Press CTRL-C for hangup
But both echo
and cat
commands for writting and reading don’t seem to reach.
I haven’t created any /etc/bluetooth/rfcomm.conf
file (I did in the past but deleted it and restarted the service).
Also hcidump don’t seem to react to any message from the server.
On the other hand, I’ve also tried to listen through rfcomm without much luck (the client informs that the connection failed because the socket might closed/timeout). I’ve added the hcidump for this case:
root@colibri-imx6ull:~# rfcomm listen /dev/rfcomm5
Waiting for connection on channel 1
Of course, RFCOMM seems to be added to the kernel.
root@colibri-imx6ull:~# dmesg | grep RFCOMM
[ 22.657552] Bluetooth: RFCOMM TTY layer initialized
[ 22.673080] Bluetooth: RFCOMM socket layer initialized
[ 22.681847] Bluetooth: RFCOMM ver 1.11
Sorry to push on this but it is quite urgent so any help would be greatly appreciated.
Thanks and regards.
(If we get this working, I would be adding this to the Bluetooth page as I find it quite useful!).
