eglCreatePixmapSurface compiles, links, and executes fine, but after drawing, the resulting buffer is always black. If I call glFinish to force the completion of the OpenGL pipeline, the program crashes without any error. It just closes and disappears without any information in the debugger or elsewhere. However, if I call eglCopyBuffers, I can get pixel buffer… but it is SLOOOOOW.
I have the following questions.
Who is the author of the iMX6 OpenGL ES and EGL implementation for WEC 2013?
Where can I get more information about what features are or are not implemented?
Where can I file bug reports for the OpengGL ES/EGL implementation with hope that they may actually be addressed?
Most Important - According to Issue 14125 (Windows Embedded Compact - iMX6 BSP Release) a new 2D/3D acceleration driver is being provided in the upcoming Q2 2016 release. Will either of the above 2 issues be addressed in that release?
on i.MX6 the CPU and GPU access the same DDR memory, on Intel architectures you may have separate memories for CPU and GPU or a GPU that can access only part of the available memory. I suppose that those functions are not needed on ARM-based devices.
Can you please upload some sample code on share.toradex.com, so we can test the issue?
(now questions, restarting from 1)
GPU driver is provided by Freescale and comes from Vivante.
You can ask here, we will try to reply and collect information from our contacts.
Here, we can’t grant a quick solution, but we will try our best to address your issues
This is a minor update, if you can provide us sample code we can test if the issues are fixed. I don’t see specific comments about those in the release notes.
I tried and the function is exported by the libEGL.dll we have in the image.
You can generate the lib yourself by installing the binary BSP, the DLL (and all other DLLs involved in openGL) are in the FILES subfolder. In this way you can re-generate import libraries matching the version you are using.
While this is a clever technique (and one which I may need), I would prefer to have the SDK released with matching .h, .lib, and .dll files so I don’t have to resort to such hackery.
I’ve been playing a little more with this API, and it appears the functions that are not in the .lib files are supposed to be resolved at runtime with functions like eglGetProcAddress. If you look in the eglext.h file, all of those missing functions have alternate prototypes cast to types like EGLAPIENTRYP PFNEGLBEGINCOMPOSITIONMSFTPROC.
However, I don’t see an equivalent function to eglGetProcAddress for gl2ext.h and its functions. Instead, I have resolved those functions at runtime with GetModuleHandle and GetProcAddress from the Win32 API.
Are there any release notes or documentation that accompanies the Microsoft/Freescale/NXP/Vivante release that I can download from somewhere to better understand the intended usage of this library?
