is it possible to access GPIOs (C programming) on iMX7 without libraries?
In the following article, it is assumed that the programmer uses the libsoc:
In the toradex-linux gpio documentation, It can be understood that the programmer has only to include linux/gpio.h and use the gpio functions:
http://git.toradex.com/cgit/linux-toradex.git/tree/Documentation/gpio.txt
A simple code accessing the GPIO1_IO1 pin would look like this:
#include <linux/gpio.h>
int main (void)
if (gpio_request(1, NULL)){
gpio_direction_output(1, 1);
gpio_free(1);}
When I cross-compile the program (using the arm toolchain) to run it on iMX7, I get the undefined reference errors for these functions.
I just want to access few output pins simply by assigning a value.
Is there any simple way to access the gpio (e.g. memory like access) that would work for Cortex A7 (would be nice if it can be ported for Cortex M4).
Majd
