If I switch from i.MX6 to T20, should I change the Toradex Libreries and use the other ones for Tegra Modules? Thanks
Dear @emmettbrown
On the Colibri T20 we offer two set of libraries:
- historically there were only the WinCeLibs
- A few years back we unified the library API between various modules and basically rewrote all libraries. These are the TordexCeLibraries
As you plan to switch from an even newer device (Colibri iMX6) to the Colibri T20, I recommend to use the new library interface (Toradex CE Libraries).
This offers you software compatibility to a large degree between the different modules.
Regards, Andy
