I got two observation for my simcom module. And I conform I am using old firmware.
By using this firmware I unable to do the SSL/TLS configuration
But, my requirement I want to configure TLS MQTT Server.
And also I got confused with this command,
AT+CMQTTCONNECT=0,“tcp://test.mosquitto.org:1883”,60,1
And I know TLS configuration done once update module firmware,
But, I don’t know, how to configure this following server?
AT+CMQTTCONNECT=0,“tls://xxxx.net:8883”,60,1
But, This is not the proper as per the document CMQTTCONNECT command begin with “tcp://”
Please provide your feedback.
1, Without TLS (old firmware)
toradex_apalis6q:/ # echo -e “ATI\r\n” > /dev/ttyUSB3
Manufacturer: SIMCOM INCORPORATED
Model: SIMCOM_SIM7600E-H
Revision: SIM7600M22_V1.1
IMEI: 867584030013333
+GCAP: +CGSM,+DS,+ES
OK
Document:
https://simcom.ee/documents/SIM7500E/SIM7500_SIM7600%20Series_MQTT_ATC_V1.01.pdf
2. With TLS (new firmware)
Document:
https://simcom.ee/documents/SIM7X00/SIM7500_SIM7600_SIM7800%20Series_MQTT_AT%20Command%20Manual_V1.00.pdf
Thanks & Regards,
VinothS
