I’ve developed an application for a i.MX6 and works pretty well.
This application is developed in C# for WEC2013 and I’ve developed a DLL in C++ that uses the Toradex libraries since with this library I can speed up my software.
Now I would like to migrate the software to a Toradex T20 but the C++ DLL I’ve developed doesn’t work with the T20 module since when I try to load a method it raises the following error: "Can’t find PInvoke DLL ‘LaserLibrary.dll’. How can I do for make it will work also on the T20 Module? What should I change in the library?
I hope you will help me.
Kind regards
