i have 2monitor
monitor1 480x800 (main, RGB)
monitor2 1920x1080 (sub, SUB)
edit Registry
[HKEY_LOCAL_MACHINE\SYSTEM\GDI\Rotation]
Angle = 180
Two monitors rotate together.
only one monitor (480x800) rotation enable?
Thank you!
i have 2monitor
edit Registry
Angle = 180
Thank you!
Dear @tlfksh7
I’m afraid the display rotation is done in the GDI, it supports only rotating all display contents at once. Rotating one of two displays is not supported.
Regards, Andy
