Hi Team,
I am working on imx6ull board. I want to access two uart (UART1 and UART2) in Uboot. UART1 is used for serial console log and UART2 is used for sending user data while loading Uboot in RAM. UART1 is working fine as seen serial log on console. But, How can I check UART2 is working or not in Uboot and is there any utility? I have made changes for UART2 as given here. Please let me know, if missing here.
diff --git a/arch/arm/dts/imx6ull-colibri.dts b/arch/arm/dts/imx6ull-colibri.dts
index 28b7ef6..9727301 100644
--- a/arch/arm/dts/imx6ull-colibri.dts
+++ b/arch/arm/dts/imx6ull-colibri.dts
@@ -86,6 +86,14 @@
+&uart2 {
+ pinctrl-names = "default";
+ pinctrl-0 = <&pinctrl_uart2>;
+ uart-has-rtscts;
+ fsl,dte-mode;
+ status = "okay";
&iomuxc {
pinctrl_i2c1: i2c1grp {
fsl,pins = <
@@ -129,6 +137,15 @@
MX6UL_PAD_UART1_CTS_B__UART1_DTE_RTS 0x79
+ pinctrl_uart2: uart2-grp {
+ fsl,pins = <
+ MX6UL_PAD_UART2_TX_DATA__UART2_DTE_RX 0x1b0b1
+ MX6UL_PAD_UART2_RX_DATA__UART2_DTE_TX 0x1b0b1
+ MX6UL_PAD_UART2_CTS_B__UART2_DTE_RTS 0x1b0b1
+ MX6UL_PAD_UART2_RTS_B__UART2_DTE_CTS 0x1b0b1
&iomuxc_snvs {
diff --git a/board/toradex/colibri-imx6ull/colibri_imx6ull.c b/board/toradex/colibri-imx6ull/colibri_imx6ull.c
index 6f6aeeb..943937d 100644
--- a/board/toradex/colibri-imx6ull/colibri_imx6ull.c
+++ b/board/toradex/colibri-imx6ull/colibri_imx6ull.c
@@ -84,6 +84,13 @@ static iomux_v3_cfg_t const uart1_pads[] = {
MX6_PAD_UART1_CTS_B__UART1_DTE_RTS | MUX_PAD_CTRL(UART_PAD_CTRL),
+static iomux_v3_cfg_t const uart2_pads[] = {
+ MX6_PAD_UART2_TX_DATA__UART2_DTE_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
+ MX6_PAD_UART2_RX_DATA__UART2_DTE_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
+ MX6_PAD_UART2_RTS_B__UART2_DTE_CTS | MUX_PAD_CTRL(UART_PAD_CTRL),
+ MX6_PAD_UART2_CTS_B__UART2_DTE_RTS | MUX_PAD_CTRL(UART_PAD_CTRL),
static iomux_v3_cfg_t const usdhc1_pads[] = {
MX6_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL),
MX6_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL),
@@ -356,6 +363,10 @@ int board_init(void)
/* address of boot parameters */
gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
+ imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads));
#ifdef CONFIG_FEC_MXC
setup_fec();
#endif
Thanks,
KG
