Is there a yocto image build service with Toradex?
My build machine failed to build an image with chromium added…May be because of the lack of memory. (16GB reccomended/ 4GB available)
Hi @dw-seag
No, Unfortunately we don’t provide any Build service. We recommend a 64-bit machine with at least 8GB for OpenEmbedded Builds.
My build machine failed to build an image with chromium added…May be because of the lack of memory. (16GB recommended/ 4GB available)
Which host distribution are using? Which errors did you get?
You can try these steps to overcome the low memory issue:
If this does not help, then you should add some more RAM to your build machine.
Had the same problem on my Ubuntu (18.04) build machine with 8GB RAM. I increased the swap file size to 16GB (from 2GB) and was able to build the image. It probably takes a lot longer, so I will just add some RAM soon.
Thanks for you Input.
