I want to know if the LCD Display HSD101PWW1 is compatible with the Capacitive Multi Touch Adapter board (http://docs.toradex.com/101942-capacitive_touch_interface_datasheet.pdf).
I will not use the capacitive touch. I need only the LVDS conversion part of the board.
Colibri Module: VF50
Carrier Board: Viola.
O.S.: Linux
Will it work ? Has anyone tested this LCD with the Capacitive Multi Touch Adapter ?
Has anyone tested the adapter with other cheap 10" LCD Display ?
Thanks.
I want to know if the LCD Display HSD101PWW1 is compatible with the Capacitive Multi Touch Adapter board (http://docs.toradex.com/101942-capacitive_touch_interface_datasheet.pdf). I will not use the capacitive touch. I need only the LVDS conversion part of the board. Colibri Module: VF50 Carrier Board: Viola. O.S.: Linux Will it work?
Looking at the HannStar data sheet it seems to use the same pinout on an equivalent IPEX 20455-040E-12 connector.
Has anyone tested this LCD with the Capacitive Multi Touch Adapter?
No, I am not aware of anyone having done so.
Has anyone tested the adapter with other cheap 10" LCD Display?
Yes, I tried it once with a cheap IVO M101NWT2 (30 bucks on eBay) and it works just fine.
