As mentioned in the Program for Server section of this:
I changed the IP Address and port number. I’m not sure if something is not being initialized properly, but I get an exception. Attached is a VS Debug screenshot of the point where the exception is thrown. Any help would be greatly appreciated
It should be:
scanf_s(“%s”, sendBuffer);
instead of
scanf_s(“%s”, &sendBuffer);
It seems that there was a typo in the code.
Thanks for the answer. I tried that last night, but doesn’t seem to work unfortunately. Please see the attached image for a log from the debug output window
Best,
Karthik
However this works:
- Initialize a new pointer (For example, char* test = new char[BUFFER_SIZE];
And after
scanf_s(“%s”, &sendbuffer);
strcpy(test, sendbuffer);
int new_len = strlen(test);
retVal = send(commsocket, test, new_len, 0);
Caveat: The capability of reading the sendbuffer at the client side depends upon how the client handles the sendbuffer (For example, the client may expect a carriage return followed by a line feed. In that case “\r\n” needs to be added to the end of test string and new_len changed accordingly).
Best,
Karthik
