The docker build failed with the following error:
Sstate summary: Wanted 278 Found 245 Missed 33 Current 1485 (88% match, 98% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: u-boot-toradex-1_2019.07+gitAUTOINC+e60e2c0d3f-r0 do_compile: Function failed: do_compile (log file is located at /workdir/torizon/build-torizon/tmp-torizon/work/colibri_imx7-torizon-linux-gnueabi/u-boot-toradex/1_2019.07+gitAUTOINC+e60e2c0d3f-r0/temp/log.do_compile.218)
ERROR: Logfile of failure stored in: /workdir/torizon/build-torizon/tmp-torizon/work/colibri_imx7-torizon-linux-gnueabi/u-boot-toradex/1_2019.07+gitAUTOINC+e60e2c0d3f-r0/temp/log.do_compile.218
Is there a solution to fix the error or is it possible to build an older Version ?
