I have Colibri iMX7 EVL board and installed linux BSP V2.8 from Toradex Easy installer first time.
when I built (LinuxImage3.0) and loaded image using USB via Toradex Easy Installer I see kernel boot issues as below:
U-Boot 2019.07-rc1 (Jul 17 2019 - 22:48:00 +0000)
CPU: Freescale i.MX7D rev1.3 1000 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 37C
Reset cause: POR
DRAM: 1 GiB
PMIC: RN5T567 LSIVER=0x01 OTPVER=0x0d
MMC: FSL_SDHC: 1, FSL_SDHC: 0
Loading Environment from MMC… OK
Video: 640x480x18
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX7 Dual 1GB (eMMC) V1.1A, Serial# 06412391
SEC0: RNG instantiated
Net: FEC0
Booting from internal eMMC chip…
45377 bytes read in 10 ms (4.3 MiB/s)
5581912 bytes read in 101 ms (52.7 MiB/s)
Kernel image @ 0x81000000 [ 0x000000 - 0x552c58 ]
Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Using Device Tree in place at 82000000, end 8200e140
Starting kernel …
undefined instruction
pc : [<00901c48>] lr : [<805d9838>]
reloc pc : lr : [<47e7b838>]
sp : 80c01f08 ip : 80c01f18 fp : fffff000
r10: abfffe40 r9 : 80c971b8 r8 : 80c08100
r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : 00000000
r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : 800001d6
Flags: nZcv IRQs off FIQs off Mode UK6_32
Code: 70e00802 70f00802 71000802 71100802 (71200802)
Resetting CPU …
resetting …
If I download Tezi image from below link and copy into USB & use Toradex easy installer it works.
https://docs.toradex.com/104970-colibri-imx7-dual-1gb-(emmc)-linux-lxde-image-tezi.tar
is LinuxImage3.0 not supported for Colibri iMX7 eMMC board?
Can you please point me the branch name which is supported on this SOM?
