- I have Colibri T20 with Iris
- I would like to connect external glasses to my Iris over DVI->VGA signal
- My glasses need composite signal
- I made simple converter “RGB to NTSC/PAL Encoder” with AD724 https://www.analog.com/media/en/technical-documentation/data-sheets/AD724.pdf
- Signal road: T20 → IRIS → VGA → AD724 → GLASSES
What have I done:
- I add 720x576i to to drivers/video/tegra/dc/mode.c
{ /* 720x576i @ 50 Hz , pixel clk @ 13.5MHz */ "LCD-PAL", 50, 720, 576, 74074, 138, 24, 39, 4, 126, 6, 0, FB_VMODE_INTERLACED, 0,},
save in in uboot setenv vidargs video=tegrafb0:720x576-32@50 ; saveenv; reset
restart and check fbset
mode “720x576-50”
# D: 27.000 MHz, H: 31.250 kHz, V: 50.000 Hz
geometry 720 576 720 1152 32
timings 37037 68 12 39 5 64 5
rgba 8/0,8/8,8/16,8/24
endmode
Where is the problem ?
I need pixel clk 13.5MHz but i see in fbset 2x13.5MHz
Who knows how to set the resolution ? 720x576i
