I burned fuses trying to make HAB work.
- I wonder if I can, somehow, revert those fuses of the Colibri module to start over with new certificates.
- I understand that the fuses are burnt within the Colibri module, so eventually I can reuse same carrier board with new Colibri module, right?
- I only burned these fuses:
fuse prog -y 3 0 0x70D0BB67
fuse prog -y 3 1 0x265CBA46
fuse prog -y 3 2 0xF43AFB41
fuse prog -y 3 3 0x55625167
fuse prog -y 3 4 0x9A919C50
fuse prog -y 3 5 0xD0A5AE42
fuse prog -y 3 6 0x970C4C81
fuse prog -y 3 7 0x7C4DC8CB
Thanks, regards,
Gaston!
