Hello
Now and then when booting my image based on torizon-core-docker.bb and the latest toradex_4.20.y branch i get an error that the on-module phy could not be found.
I also experience this behavior on the latest torizon-core from tezi.toradex.com:
U-Boot 2016.11-1.0b1+g07edca0bb8 (Jan 01 1970 - 00:00:00 +0000)
CPU: Freescale i.MX7D rev1.3 996 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 38C
Reset cause: POR
DRAM: 1 GiB
PMIC: RN5T567 LSIVER=0x01 OTPVER=0x0d
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Video: 640x480x18
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX7 Dual 1GB (eMMC) V1.1A, Serial# 06476991
Net: FEC0
switch to partitions #0, OK
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
2173 bytes read in 14 ms (151.4 KiB/s)
## Executing script at 87000000
445 bytes read in 123 ms (2.9 KiB/s)
48090 bytes read in 119 ms (394.5 KiB/s)
7528960 bytes read in 290 ms (24.8 MiB/s)
2804984 bytes read in 177 ms (15.1 MiB/s)
Kernel image @ 0x81000000 [ 0x000000 - 0x72e200 ]
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Loading Device Tree to 8fff1000, end 8ffffbd9 ... OK
Starting kernel ...
[ 0.841722] caam 30900000.caam: failed to acquire DECO 0
[ 0.847070] caam 30900000.caam: failed to instantiate RNG
Starting version 241-9-gc1f8ff8+
Resolved OSTree target to: /rootfs/ostree/deploy/torizon/deploy/d0a8ffe53ac06f7b593886474584ebf95cfe9805a196be75397efc254d263073.0
[ 3.437133] sd 0:0:0:0: [sda] No Caching mode page found
[ 3.442500] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 8.853484] libphy: PHY fixed-0:00 not found
[ 8.857766] fec 30be0000.ethernet eth0: could not attach to PHY
TorizonCore 1.0b1 colibri-imx7-06476991 ttymxc0
colibri-imx7-06476991 login:
I really didn’t pay attention when this happens but i do now - most of the time i am pressing the reset button on the eval board.
Can this be related to 50890_U-boot: “Could not initialize PHY FEC” Issue After Software Reboot when uboot doesen’t get to do its things?
