USB Device Error
I have a multi tech mdot plugged into the USB port of the colibri evaluation board. When running a read/write situation to the USB port (code is attached) it seems to run for about 2 minutes untill I get an error with the USB port which causes the USB to restart and breaks the code that is running. I have attached a photo of the error. Can I please get some help with how to stop this from happening ?
Michaellink text
What exact hardware (module and carrier board) and software versions of things are you talking about? Please include textual log files captured from the serial debug console rather than screen shots of the issue in question. Thanks!
