In my project I am only using the LVDS to output a display. From the data sheet I saw this statement regarding the LVDS output.
The parallel RGB is used by the LCD Interface(which i am not using).
It state that the LVDS will serialise the parallel RGB signals.
In the device tree could I disable the LCD and use the pins for other GPIO usage?
