Has anyone had any luck running the Hello_world example from DDR memory? We can run the TCM examples but the DDR examples are not working for us.
We have started looking into it but I thought I would post here to see if others have already run across an issue.
Dear @mccandlt
I have some questions to better understand your environment:
- How exactly are you building the example
(e.g. just starting build_ddr_debug.bat ?
- If you modified the default examples, please send me your modifications. Especially if the modifications are in the project settings or linker script file.
Regards, Andy
