Dear All
I am trying to make a Qt application QML-GUI that will show live streaming of ip-camera. but when in run qt-application on my Embedded Device then I got
Some problem .
gst-plugin-scanner:1296): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgstopengl.so': /usr/lib/libgstgl-0.10.so.1: undefined symbol: gst_gl_shader_set_uniform_matrix_2x3fv
** (gst-plugin-scanner:1296): WARNING **: could not find config file '/home/root/.config/gst-openmax.conf'.. using defaults!
(gst-plugin-scanner:1296): GLib-GObject-WARNING **: cannot register existing type 'GstVorbisDec'
(gst-plugin-scanner:1296): GLib-CRITICAL **: g_once_init_leave: assertion 'result != 0' failed
(gst-plugin-scanner:1296): GStreamer-CRITICAL **: gst_element_register: assertion 'g_type_is_a (type, GST_TYPE_ELEMENT)' failed
shared memfd open() failed: Function not implemented
Warning: "No decoder available for type 'application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d0029, sprop-parameter-sets=(string)\"Z00AKZpkA8ARPy4C1AQEFAg\\=\\,aO48gA\\=\\=\", a-recvonly=(string)\"\", npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1'."
Error: "Your GStreamer installation is missing a plug-in."
I am using –
Embedded Device(SOC) – Colibri-T20 (NVIDIA,Toradex)
Os - Angstrom v2017.12 – Kernel
Colibri-T20_Qt5-X11-Image 2.8b6 20190816
Which package I am missing in my os
If am running this application on my Linux Desktop and imax6 it works correctly .
