Kernel Configuration for imx6ull
We are doing kernel configuration process for which path exporting, defconfig, image and tree building are done. But we stuck in the kernel configuration manual setting step. We are using (make imx6dl-colibri-my-carrier.dtb ) command for it. But we don’t what should be the correct input for those questions. Is there any reference to know whether we are going in the right direction or not?
Looking forward to hear from you as soon as possible.
Thanks,
Sanskruti.
Dear @sanskruti ,
Thank you for your enquiry!
Please kindly follow the procedure in the link below for Kernel Configuration/ Updation.
Other useful links:
Janani.
